IQR running board upgrades
Dec 15, 2007
151
24
PA
I got a bit side tracked at work Friday morning :lol: go figure! I have been meaning to do something to get some snow off the running boards that just build up when riding the fresh pow. Stay tuned for another custom long track coming next week. This is my junk for now.
This is the best pic of the stock running boards
Started by using a 2" dimple die to add some strength
Next cut out the running boards
Then added some traction! This should be enough to tear a knee open. HAHA!
Par129
Nov 22, 2010
9
38
I have been looking at doing this to my IQR. Where did you get your grip tread from?
Dec 15, 2007
151
24
PA
Made it here at our shop. There just small pieces welded in from the bottom. If you can Tig weld alum or know someone that can I can get some pieces to diy.
Par129
Nov 22, 2010
9
38
Thanks, We have a Hi-Def Plasma table here at our shop so I will just make some myself. Thanks for the offer though. Did you just use the Cut-off wheel on the Dremel or what?
Par129
Nov 22, 2010
9
38
Hutch25 I used a 4.5" angle grinder with a cutoff wheel to do the major cuts & a Dremel with a cutoff wheel to do the small cuts. Worked good.
meathooker
1,656
625
Boise, ID
what kind of hi-def do you guys have? we have multicam... works pretty well
Par129
Nov 22, 2010
9
38
What we have for a system is a Retro Systems Super Hornet that uses Phoenix Motion Control Software W/Hypertherm HPR260 power source. We many do Tank & Vessel construction for the Ethanol Industry. Multicam makes a good product.
