Long Range LED Auxiliary lighting
These new Lights have just been released... They are not even on our site yet!
Long Range LED lights. LED's have long been known to be very bright but not to really give much as far as distance.
That changed last year with our new PENETRATOR series Led Light bars.
The new Long-Range out perform that mark greatly :face-icon-small-sho
This light has now won many Motorcycle races and have proved to be extremely reliable.
Now we are introducing the CYCLOPS OPTIMUS LONG RANGE LIGHTING in a 10 deg. beam they are good for 660 ft of true useable light with only a 10 watt power draw.
That is less than TWO amps for two lights!... Run them off the FUSED connector in your Polaris PRO-RIDE Accessory power wire and keep the safety of the factory installed fuse!
I am very impressed with these small 3 inch lights in quality and performance...
Truly an evolution of our LED lighting technology and available to the public.
I have not seen any LED light even come close to the distance these can throw light.
They are available in 10 and 20 degree beams with 40 deg coming in a few months.
For now, Black is the only available color but grey,white and chrome are coming soon.(additional cost for chrome)
This is by far the longest throw, lowest power usage Light available.
Don't be fooled with Lumen claims.. Lumen ratings really mean nothing in real world performance.
Lifetime warranty:bounce:
I can set you up now with a PM or phone call.
- Only 3.5" Tall (about the same size as a typical "post-it" sticky-note)
- 693' of Usable Light from 10-watt LED
- Proprietary IRIS Reflector Technology
- Prime Drive Technology Thermal Management
- Dimming Capabilities
- Narrow, Wide, and Flood Beams
- IP-68 Waterproof
- Single is 620 grams
- Double is 1100 grams. (for ref. a pound is 454 gr)
Note on weight: If a high performance LED does not have a bit of weight to it there will be an issue.
1) Performance LED lights create a lot of heat.
2) If a light does not have enough heat sink material (copper) it will eventually over heat and have thermal breakdown.
This is very common with many low priced LED lights
Pricing:
Long Range Single - $139
Long Range Single KIT (2ea lights w/Wiring Harness) - $259
Long Range Dual - $239
Long Range Dual KIT (2ea lights w/Wiring Harness) - $459
