The only thing I would like to see on it is some sort of rubber vibration dampner? With the longer bolt if I remember on the old twins the vibration took its toll!
Mike
Mike
Did you check your belt to sheave clearance? Where it is now adjustable it may be too tight.
P.S. We have these in stock now for the M7, M8, and M1000.
According to the manufacturer's description, upshift and backshift is improved .
Can somebody please explain ,to me, how this is accomplished? Once your clutch is engaged, the ENTIRE part is out of the picture.
400% more bearing contact. Shouldn't this read 400% more bearing contact AT IDLE ONLY?
Does anybody know how a sliding hammer works?:face-icon-small-hap
"It is right at engagement with the belt that the cover needs the most support to keep it from cocking and binding. Sure, there is another bushing down at the bottom in the movable sheave, but that's at the bottom. The top is left with little support."
"add big power engines, things like 150-160 HP 800 twins, 1000 cc twin's, and 1100cc Turbo-charged four-strokes the need for as much support and alignment becomes even more critical. It shouldn't take a rocket scientist to realize the benefit from adding support to this area."
"Even if you discount the bushing support argument, you know full well how much you need an external side clearance adjuster!"
Just a few quotes from the Thunderproducts website that should help define the purpose of this piece.
I hope these pictures help. I am not completely sold on it yet either but I took the bait. I think it will align really well if the clutch is assembled (spring and cover in place) when you install it I worry more about the bolt. I have never taken my bolt out yet of the stock clutch but where this bolt is machined I worry about it breaking.
Rob
BTW the crap on the threads is from my floor.
Great pics.. thans for taking them..
It LOOKs like the added support is locating on the inside of the clutch shaft... this is a good thing..
So, thoughts #1 and #3 still need to be addressed... Any thoughts on #1 and #3??
On number one the only gain in up shift would be if you moved the spider too. In this case the spider stays in place and the shift moves. Unless you move the mass center line of the weights you will not see any more up shift than stock.
On number two the outter sheave would bang like a slide hammer on the spider the same as this stopper in the end of the bolt. I am sure in time it will take its tole but one would have to run it and keep checking it with a new belt.
If you are really anal at keeping .020 belt to sheave then this product will be great. As the belt wears move in the secondary the same amount you close up the belt to sheave as the belt wears.
Don.
