Upgrade to Premium
Reply
  #1
Old 02-14-2008, 01:47 PM
SledHed75 SledHed75 is offline
Currently: Not set.
Basic Member
SledHed75 is an unknown quantity at this point
Default chaincase lube for rmk 900
I need to buy some lube but i dont feel like spending the $ for "Polaris brand lube" and besides the polaris dealer is 45 minuets away. What is the equivilant to use? Thanks
Rate this post: Yes | No
  #2
Old 02-14-2008, 01:58 PM
skibreeze's Avatar
skibreeze skibreeze is offline
Currently: Loving the new Silber external wastegate turbo!
skibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond reputeskibreeze has a reputation beyond repute
Default
Use ATF, you'll be just fine. You can use darn near any type of oil though.
__________________
http://avalanche.state.co.us/
  #3
Old 02-14-2008, 02:05 PM
TravRMK TravRMK is offline
Currently: Dreaming of powpow
TravRMK is an unknown quantity at this point
Default
Yep, use a good ATF. I like the sythetic stuff, and you get a whole quart for a fraction of what the Polaris lube costs, and it is enough to do several sleds.
  #4
Old 02-14-2008, 02:56 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Synthetic old school chain type transfer case oil.
  #5
Old 02-14-2008, 03:06 PM
ivar ivar is offline
Currently: Not set.
Basic Member
ivar is on a distinguished roadivar is on a distinguished roadivar is on a distinguished road
Default
Quote:
I put in ATF this time. Dealers around here puts in 10W-30 engine oil.
IMO, more important that the oil is not full of water and metal shavings than what type is used...
  #6
Old 02-14-2008, 04:12 PM
Currently: Not set.
Basic Member
Default
cool, thanks guys!
  #7
Old 02-14-2008, 06:45 PM
donbrown's Avatar
donbrown donbrown is offline
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
Same here ... tranny fluid and less shavings in the chaincase.
  #8
Old 02-15-2008, 12:05 AM
Currently: Not set.
Basic Member
Default
i pulled my dipstick and noticed metel shavings on the magnet and not much oil. If i pull the cover to clean the metal out do i need to buy a new gasket? or is it reusable?
  #9
Old 02-15-2008, 12:26 AM
donbrown's Avatar
Default
Quote:
Small metal shavings are normal. Chucks of a gear or chain are bad.
There should be a safe range on the stick. Keep oil level in safe range. It is not normal to loose lots of oil after one tank of fuel.
Switching to transmission fluid will have less shavings.
  #10
Old 02-15-2008, 11:41 AM
410Fortune 410Fortune is offline
Currently: Not set.
Basic Member
410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute410Fortune has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
