Now 10% during Thanksgiving weekend: Sonic, Turbo Systems from Turbo Performance
Hey guys, only during Thanksgiving weekend get your Turbo System with 10% off.
Also, get your Skii Doo XM and Freeride with a $1,400 discount.
Visit us www.turboperformanceind.com
They are here. Meet Sonic, Turbo Systems for your Ski Doo 850.
Again, the best materials and parts, more boost and the quality of a product made by Turbo Performance is here for you. All of that for less money compared to any competitor.
If you want more information or get yours, call us 801-807-8046
Sonic Z: Everything you ever wanted in one package. Put together for professional racers in mind. OEM quality. Amazing value over the competition. With a Garret Turbo and Racers Package.
Sonic X: Everything you ever wanted in one package without all the bells and whistles. Put together for weekend professional racer in mind. OEM quality. Amazing value over the competition. With a Garret Turbo and Red Line Fuel Controller.
Sonic R: All the high performance without the high dollar price tag. Put together for the weekend racer in mind. OEM quality. Unbeatable value over the competition.
Available add-on component packages:
Sonic Fuse: The first turbo kit that you can put together by yourself. Best material and components at an unbeatable price.
Basic kit:
Come and join the revolution. Look up!
[*]Garret 2860 RS Turbo.
- 2.5" aluminum charge tube.
[*]Tunable Red Line Performance Fuel controller.
- Billet aluminum before throttle body secondary injectors.
- Properly sized aluminum air box.
- With compression style connections.
- Simple non-chassis modification install.
- 3" aluminum intake.
- Deka match fuel injectors.
- OEM fit and finish.
[*]Boost levels ranges 4-12 PSI.
- Custom designed Turbosmart blow off valve.
- Pull and go consistent performance.
- Altitude compensation fueling.
- Lightweight design, it adds less than 6 pounds.
[*]Racers Package
- Includes Turbo Performance proven components used for over 10 years.
- Billet oil tank.
- Billet Intake fittings.
- 10.000 hours rated aviation oil pump.
- Plug and play wiring.
- AEM AFR gauge.
- Boost gauge.
- Gauge bracket.
- Clutching.
- Stainless steel oil line.
- Double ribbed constant tension clamps.
[*]Tunable Red Line Performance Fuel controller (AFR recommended).
[*]2860 RS Turbo.
[*]Preset to 6 PSI boost.
- Gauge Package
- Oil Pump Assembly
Basic kit:
[*]Choose between a Garret Turbo or a 2860 RS.
- Pipe Assemblies
- Air Box Assemblies
- Billet Intakes
- Charge tube assemblies
[*]Tunable Red Line Controller (AFR gauge recommended)
- Fuel line assemblies
- Air Line Package
- Coolant Line Package
- Gauge Package
- Cold air Assembly
- Oil Pump Assembly
- Clutching
