I just pulled my primary off and the rollers and ramps are in great shape but the orings behind the buttons are in pretty bad shape. The question is should I replace the buttons as well as the orings or jus tdo the orings.
What rattle are you referring to; I have noticed a rattle around 6200 rpm but it goes away at around 6700. Could this be the problem. Any help is appreciated.
Thanks
The buttons typically show wear on the sides....not on the wear surface. Doo leaves a nice sharp machined edge to dig into them. I break that edge just slightly with a deburring tool, not sure how much it may help but it can't hurt.
If they are worn on the sides I replace them, that's where the "rattle" comes from.
The edge you are talking about, is it on the button or the clutch?
Anyone using an o-ring from the hardware store or less expensive option with success. Ski-doo is looking for $2.49 per o-ring.
