I have been having hard starting issues with both my M8000 and my M8. They both have had issues starting after the engine has been running for quite some time and are fully warmed up to operating temperature. One of the suggestions to remedy this problem was the throttle cable may be too tight and to loosen the tension.
I can say that on both sleds the throttle cable freeplay is correct with the handlebars all the way up. However, when I lower the handlebar height, the idle speed increases as the bars go lower. With the bars are the lowest position the engine is just under clutch engagement RPM.
So maybe the throttle cable is too tight? I am thinking about lowering the bars all the way down and setting the freeplay and idle speed in that position but, I am worried that if I do the throttle bodies won't open all the way.
How are you with adjustable steering posts adjusting your throttle cable?
Here are links to the two hard starting threads I referred to above.
http://www.snowest.com/forum/showthread.php?t=407446
http://www.snowest.com/forum/showthread.php?t=367670
