The helix angles that Mark (Team Industries) listed are not currently available. They are going into production soon.
Did you use the shim for the TSS-04 or TSS-98 Clutch? I don't see one for the Tied?
I agree that this is what is going on. So is it better to take the float away and lose the rattle, or just ignore the rattle? Is the rattle doing any damage in the long term?
Speaking of getting stuck in a spot with the Tied, has anyone looked at their helix rollers?
Do you have deep chatter marks on the inside half? I did. Just wondering if anyone else has seen the same.
If your out there TEAM, did you see the same testing the PC?
This is a good ? Now if you take the float away you will be doing several things....the rattle on the splines goes away and so does any wobble in the float plug and inner bushing because its hard mounted to the TCL bearing like the stock secondary. If you have your alignment spot on this should be fine! However team doesnt have their alignment bar yet and my stock and team clutches were not the same so I had to shim appropriately to get the team clutch at the correct offset (well correct according to the cat bar anyways!). With all the movement going on in the TCL and jackshaft I really do think the float does a lot for this sled though. Here is a head scratcher for ya; with the out of parallel that the clutches experience due to all the motor/jackshaft movement the "parallelism float" in the float plug may be working in our favor??
Regarding alignment has anybody else tried pulling all the shims behind the secondary (note that the inner most one is not a shim it a retaining ring for the bearing dont remove it), giving the float plug a generous amount of room (say 1/4in) and running their sled on the stand to see where the clutch wants to naturally float to and align itself in a happy place? Its hard becuase you will see how much the clutch vibrates around on the splines...but when i did this my secondary always floated all the way in against the jackshaft?
Geo I just checked and my rollers are wasted flat spotted and there is tons of "dust" all over the helix behind the roller pin!
The 20 tooth gear was definitely the big part of the recipe. The updated helix with the .36 also made a big difference on consistent RPM's. The 71-55.36/71-57.36 was definitely better in every condition we tested in. I tried straight cuts and many different progressives while we were out there along with a lot of different spring combos. I think the 163 length probably will have to run the red pink with this set up.(our 800 was a 153)
We still have the stock belt so far on our 800.Belt temps varied on different snow conditions but always could stop and remove the belt without using a glove and getting burned.
jkjasperson: We have plenty of the 73-57ER .46 in stock if you need one.
