Remove Silber for trade in and now it’s kicking a red code
Coldestwinter1
172
31
New york
I removed the turbo this weekend to put it on the new sled and when I started up the sled it fires and turns right off if I give a little throttle it’ll run but as soon as I let off it dies and the check engine light comes on throttle response switch I think is what it says any ideas what’s wrong?
Wheel House Motorsports
29,933
5,970
SW MT
Easy enough to end up twisting the cable routing some and causing it to increase tension, make sure there is throttle free play per oem spec. Loosen it up and it probably is whats wrong.
Coldestwinter1
172
31
New york
Yup it was the throttle cable all’s good now can’t wait to pickup the sled! Any suggestions on things I might should look at or maybe replace with the kit it’s got about 500 miles on it?
