Mcx fuel filter
W
Winter Nutz
120
160
Cranbrook BC
a2.sphotos.ak.fbcdn.net
I'm having fuel problems. Low pressure. I have a inline filter was plugged. Is there also I filter in the tank pickup for the new style nytro 270 kits?
And what should fuel pressure be at idle? Then how much does it go up per pound of boost?
M
Jan 14, 2004
3,079
1,390
It should have the stock in tank one mounted to the alu plate that replaces the fuel pump on the 270 kit. You can just undo the bolts and pull the plate, just be careful with the gasket, they can be a PITA to get back in as the gasket will swell.
M5
up-high
299
83
71
Alberta Canada
Also check your fuel lines(return line also). I think fuel pressure is 45lbs. That's what it was on the Apex.
B
BigFish BC
3,348
1,139
kitimat b.c
always run 38-40lbs not sure if the mcx is diff & pressure should rise with boost appox 1 lb of boost for 1lb of fuel pressure.
N
NM
1,195
1,000
Ponoka AB.
Fuel pressure should be about 44 without a vac line attached to the regulator, if you run the sled with a vac line attached it will pull fuel pressure down slightly, the amount will depend on how much vac your sled makes.
