why are the ecu's and voltage regulators blowing on 09 d8's?
T
335
83
coeur dalene, idaho
Does anyone know or have an idea on why the voltage regulator is causing the ecus to go bad? IS there a fix coming, will my votage regulator and ecu go out again?
thanks
tim
rmkboxer
323
83
46
Bonney lake WA
on a friends 08 the harness rubbed through on the clutch guard and ended up taking out the ecm. the dealer showed him the harness where it had rubbed through
stem
454
86
Norway
I had this problem on my 07D7 and it came from the resistor conected to the voltage regulator, when this blew the voltage regulator got too much power from the engine and blew, wich again caused the voltage to be to hig in to the ecu and thereby frying this.
It's a small fix but could help you save alot of $ and help you cut down on the :mad: times
D
deepdiver
936
316
Marysville, WA
thanks
tim
easy...maximize profits and minimize costs. Unfortunatly when some large corporations do this the greed mentality takes over and they fail to balance realibility, durabilit and quality with corporate earnings. Can you say Made in China??
rmk727
568
154
SO.DAK
I wish someone would have tried relocating the ecu and regulator or putting a cold air vent to it as if you look it's the only major change from the 9's and is in a really hot part of the sled also the ground might take a beating there
