Losing rpm
E
Aug 20, 2011
453
99
Soo/Menominee MI
Ok, so Ive been riding my sled and noticed something is acting up. When I punch it from a stop the rpm will shoot straight to 8000-8100, then it will dive down to about 7300 then finally continue to pull lazily up to around 7900ish. Any ideas why? Belt has about 1300 miles on it looks good.
about 1950 miles, low elevation weights and secondary helix.
Checked power valves, cables, secondary spring, rollers, helix. Everything looks good.
ranger12
522
333
Dickinson ND
What year sled?
Are they still the factory springs in the primary and secondary? I would start by replacing the secondary spring first and go from there. The spring might look good but is probably sacked out. Make sure your weights move freely in the primary with the cover off.
E
Aug 20, 2011
453
99
Soo/Menominee MI
What year sled?
15 high country
It's the secondary, they suck. Get it fixed
what do i have to do to get it fixed?
ranger12
522
333
Dickinson ND
Do you have a new belt and a caliper?
Measure across the top of the new belt and then measure the old belt that will tell you how worn out it is. Plus your old belt is probably hard and not grabbing the sheave surfaces correctly anymore. I would say that you have more than enough miles on that belt. Keep it as a spare and install a new one. It will help with your problem but I would still look at the secondary and the secondary spring also and install a new spring. The springs don't cost much but if you install a new spring you will be able to get a good look at how everything is wearing in the secondary when you have it disassembled.
E
Aug 20, 2011
453
99
Soo/Menominee MI
I did measure the existing one and its 1.40 on the dot width. I have a dayco xtx thats brand new to use, gonna give that a shot. Also gonna hop in the car and head to the dealer thats an hour or so away and grab a new spring.
WyoBoy1000
11,213
3,928
Red Lodge MT to North, CO
Stop for f cking around. The stock secondaries are not right, ppl think they work but reality is there not running efficient.
Send it to Mountain valley motor sports in Cody, wy. And get it machined.
That is the only true fix. Everything else is a waste and you will never have what you could.
B
Sep 24, 2009
605
136
Yakima Wa
a new belt has a small angle cut at the top of the cogs. Your belt will run a long time before wearing that angle off all the way to the top of the cog. If you've worn the sides of your belt all the way to the top of the cog, then your belt is shot & it will still measure close to new. If you were happy with the performance of your sled before, then clean your clutches, scrub that new Dayco with hot soapy water & go enjoy another 1300 miles. If it doesn't run right, start throwing money at it.
clutch
200
Big Horns Wyoming
Check the rollers on your primary. Make sure the weights are still centered and the set screw isn't loose. A spring isn't going to make your rpm do what you're describing. Check belt and deflection.
ranger12
522
333
Dickinson ND
With a user name like you have, can you please describe to me how a sacked out secondary spring with 1300 miles on it would not cause his rpms to do what they are doing? I'm not saying that it is the only problem that he has either.
I cant believe I just did that! That is why I don't come on this site much. And I probably know you.
clutch
200
Big Horns Wyoming
A worn out spring may cause it to lose 100-200 rpm from new, but it won't cause it to jump up fall off and lose 800 rpm and then slowly come back up. Either it has a roller failing or something is binding in one of the two clutches. Did it just start doing this, or did you change something and then it started?
ranger12
522
333
Dickinson ND
When I read the post I took it as everything was fine until he just hit 1300 miles. There could be several things wrong here but I was just referring to the simple things first to check that are the least amount of money to start with and he more than likely needed. One of the things that I suggested was that the secondary spring is shot, which if it doesn't have the right amount of resistance anymore will open up the sheaves too quickly and put it in too high of a gear and drop the rpms and then when everything else catches up the rpms will start to creep back up slowly. Yes the machining of the secondary is a big improvement but if he was happy with it for 1300 miles he probably doesn't have to have it done. I also started that if he changed the secondary spring he would have to take it apart to do that and then he could inspect the rest of the parts. There could also be problems in the primary as some have started.
I just reread the original post and it says 1950 miles on the machine. I must have missed that the first time. That's getting to be a lot of miles on the Cat clutches!
Betterview
234
88
Central Minnesota
I agree with Wyo that your problem is most likely in the secondary.
If you get 8000 plus when you punch it tells me you are in the ball park on clutch weight. Then what is probably happening with the Chinese built two roller secondary is it is wobbling and over shifting. MVM is a good choice for a fix as long as they also have your helix too.
I have had great results with a Thunder Products Hercules Helix in a secondary that would over shift so far that the engine would eventually bog out in a long deep powder full throttle pull. Talk to Lon, get his helix and his spring (it is much softer), take about three to five grams off each motor clutch weight(I ended up taking five out of mine but was a bit heavy before the change), and you will have a runner. Have done this twice. On my sled I also did his 911 clutch cover and glide washers and my clutching is as buttery smooth as any Polaris I have ever ridden while still retaining that instant aggressive pull that I relish whenever stabbing the throttle on the 800 cat.
