Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 03-22-2018, 01:58 PM
Cwoods333 Cwoods333 is offline
Currently: Not set.
Basic Member
Cwoods333 is an unknown quantity at this point
Question 2008 m8 engine cut out
I have a 2008 M8 and the engine cuts out(like hitting the kill switch) while letting off the throttle, once I let all the way off it comes right back on and acts like it is stuck in "high gear". Again once I let the rpms get back to normal idle and get going again it is fine. It randomly happens every 5-10 minutes. Any suggestions on things to check? The tss has already been disconnected.
Rate this post: Yes | No
  #2
Old 03-23-2018, 11:59 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Stuck in high gear? As in you stop the snowmobile and the idle is high? Or it just keeps moving forward and won't come to a stop?
  #3
Old 03-28-2018, 09:49 PM
Currently: Not set.
Basic Member
Default
Once I let off it will continue to rev at 2500-3000 for a few seconds until i hit the throttle again.
  #4
Old 03-28-2018, 09:55 PM
summ8rmk's Avatar
summ8rmk summ8rmk is offline
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Frayed cable?
Catching sometimes?
  #5
Old 03-29-2018, 09:24 AM
jim jim is offline
Default
Check throttle function from cables to butterflies...make sure they are closing. Could be a lean condition from an air leak also.
  #6
Old 03-29-2018, 01:56 PM
Currently: Not set.
Basic Member
Default
I've checked the throttle cable and everything seems to be moving correctly, It very tight at first so I loosened the cable and it is still happening.
  #7
Old 03-30-2018, 06:55 AM
mbcat mbcat is offline
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default
Check spider in primary clutch closely for cracks. Sounds like it's goin on yah. When it acts up & you blip throttle the clutch frees up.
  #8
Old 03-11-2019, 05:07 PM
Currently: Not set.
Basic Member
Default
Update if anyone else had this problem. The belt that was on the sled was getting worn out and too narrow. Picked up a new belt for this season and it hasn't happened again.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2008 RMK 700 engine or compatible engine with chasis Thread Starter — bizzy4play Forum — Polaris Replies — 2 Last Post — 11-24-2015 09:42 AM
Thread — Custom kid sled with cut in half 800 polaris engine Thread Starter — NYPRO Forum — Member Sled Builds Replies — 1 Last Post — 11-30-2014 10:39 PM
Thread — To cut or not to cut (powderhound skis) Thread Starter — galljr13 Forum — Mountain/Deep Powder Replies — 1 Last Post — 01-14-2014 05:27 PM
Thread — Boondocker Turbo Pro Engine Cut out or Bog in Midrrange. Thread Starter — Hollywood99 Forum — Polaris: TURBO Replies — 3 Last Post — 02-13-2012 06:02 PM
Thread — 2008/9 IQR...What engine work is needed to make it a decent mountain engine? Thread Starter — mountainhorse Forum — Racing Replies — 4 Last Post — 07-23-2009 01:22 AM
no new posts
