I have a 2009 M1000 with full slp kit with a pc3 controller, The sled has 2500 miles on. My question is doing a compression test will that be enough to lead me to redoing top end or not? I plan to pull head and exhaust, From reading many of the post on the 1000 seem like excessive wear causing too much play in cylinder resulting in a piston skirt failure is most common issue. Also will a wiggle test give me an information(with head off see how much wiggle there is with each piston)? Thanks for reply's,
