Will 2015 pro shocks fit 2016 axys?
Jay
635
Smithers, B.C.
Will the front resevoir shocks from a 2015 pro fit and work on a 2016 axys pro?
Teth-Air
4,566
2,795
Calgary AB/Nelson BC
www.specified.ca
I know the early Pro shocks used heavier hardware and had a heavier strut rod but the extra length on the Axys was below the shock mount so it might be the same length. I used an older Assault shock on my 16 Axys until I could get it fixed and that one was slightly longer as those had a wider ski stance.
Jay
635
Smithers, B.C.
Thanks. Would any axys chassis shock fit any axys chassis? Ie would the shocks off a 2020 850 fit a 2016 800?
05rmksteve
2,486
1,627
Brainerd, MN
11-12 pro rmk shocks where longer than the 13-15 pro rmks and yes the assault shocks where longer because the assault had a wider ski stance. The length of each shock I dont remember any more. As far as the axys question it should be the same length as long as it doesn't have the react front end or an assault or kahos. The react is a narrower ski stance vs the standard axys rmk assault is wider.
Jay
635
Smithers, B.C.
Thanks guys, great info. I recently bought a 2016 pro 800. Stock suspension. I would like to put a set of remote resevoir shocks on the front, skid also if I can find a set. Would it be worth it or not?
Teth-Air
4,566
2,795
www.specified.ca
Basically look at the ski stance width. Shocks form a 38 inch wide AXYS will fit another year 38" wide. The Assault is wider, the 19+'s are narrower. And older ProRide chassis use thicker bolts to mount so new bushings would be needed.
sledhed
1,751
435
Lolo, Montana
Stock shocks on 15 Pro RMK (not standard rmk) and stock shocks on 2015-2018 Axys RMK are the same length and interchangeable - the original question. When in doubt, just measure eye to eye length. Rear shocks are not the same Pro->Axys though.
