Will the front resevoir shocks from a 2015 pro fit and work on a 2016 axys pro?
That depends on if you have the stock 2016 arms. Up through 2018 arms were a 39 inch stance width. 2019+ have the react 36" width which uses an even shorter shock than the older axysThanks. Would any axys chassis shock fit any axys chassis? Ie would the shocks off a 2020 850 fit a 2016 800?
Basically look at the ski stance width. Shocks form a 38 inch wide AXYS will fit another year 38" wide. The Assault is wider, the 19+'s are narrower. And older ProRide chassis use thicker bolts to mount so new bushings would be needed.Thanks. Would any axys chassis shock fit any axys chassis? Ie would the shocks off a 2020 850 fit a 2016 800?
