Rear suspension mount points measurements 2013 proclimb
mckinney
161
20
18
48
Evans, Co
Does anybody have the measurement between the two rear suspension mount bolts for a 2013 proclimb? Reason asking is that suspension is going in another sled.
mckinney
mckinney
161
20
18
48
Evans, Co
Share a photo for that sled
Here is what I have. I have the spacing set at 31.25. It sits low and the rear swing arm is not near vertical. Have 75 psi in rear shock.
boondocker97
4,077
2,795
Billings MT
That skid in a Cat would have 125-150psi in the rear shock depending on rider weight. Might want to consider adding the braces to the rails at the front arm connection that the 4 strokes and HCR had and then were standard across the board after 2015.
mckinney
161
20
18
48
Evans, Co
I will pump more air pressure into the shock and see.It seems to have a lot of sag before the shock comes into play. Also look into the braces. Thanks
