I
We will refund you even if Vforce doesn't Larry.
Looks like we are in the same boat. I have the 860 mentioned earlier in the thread. No questions it was the reeds causing the idle issue on mine. From what I had heard it was more than needing to break in and they are "working" on a fix or update or something. I sent mine back in and will wait till I hear there are less issues before ordering a new pair. Probably a next year deal, would be my guess...
PV
(oh, and the BMP 860 is a very impressive performance increase. With 72 gram belly busters it was pulling 8200+ and spiking to 8500 at 1300 feet this weekend. Limited snow and super short up hill pulls so not really a true test. We'll see how it does in some real snow, if we find any more this crappy year...)
I'm Running 73 grams in mtx wieghts.
Stock bore. 62-42-40 helix
Black purple sec. Green pink primary.
Pulling 8150 consistently at 2400-3500'
Sunvang, you will need to pull around 10-15% fuel from your lowest rpm fuel setting in order to get it to idle. Or pull the VF3R reeds. I pulled my reeds and installed the stock ones and I was able to go back to 0% fuel setting and it idles like a stock sled. Or try waiting it out like others have stated. To me, I don't want to have to give it gas every time I start it like a carbed sled...
Im running the 3R in my Fastrax 800cfi. Curtis told me to highlight the whole map from 0-20% throttle and from 0-clutch engagement and do -4% or so.
And if you really want, -10% JUST at idle. That should clean it up.
ok, one more to join the part.
My 2011 pro rmk was fouling a bit to easy and I suspected the reeds. About 2000km on sled.
Changed reeds only. Good running sled with PAR 12:1 head, gear down and clutch work + slp torque arm.
Sled now has these idle problems that cannot be solved by idle setting. But it also pulls really strong! DET problem came lurking again, the "to-fast-engine-rpm-increase" DET. Full throttle is no problem as long as you ease into a bit.
Will say these reeds appear to be working good, but messing a bit with the idle setup. Think I want to either get the TPS to correct it or finally install a fuel box.
A bit on the side, but are people happy with Boondocker box for adjusting these sleds? No turbo or massive mod.
