installing 7s screen on Matryx RMK
kylant
1,668
394
CA
i have one on warranty order. hopefully it shows sooner than april
kylant
1,668
394
CA
what all is necessary to add a 7s to an e-start standard gauge sled?
housing
gauge
install kit
gps antenna
v2v antenna
v2v harnes
but what about the wiring harness coming off the battery? does anything need to be changed there?
m1kflyingtiger
1,045
481
Soldotna, AK
My ‘23 snowcheck was an in season allocation. The Polaris rep moved it to snowcheck so I could order it but said it had to be ordered as spec’d accessories or changes had to be just ordered through the dealer and dealer installed. Then within the hour they made the 7s not available for accessory order. Been waiting all summer, just called Polaris about it and they said it’s now pushed back to December.
kylant
1,668
394
CA
They are available for priority warranty replacement.
“Not available” for purchase as accessory.
Not really available for damage replacement.
any insight on how to make this happen quicker? mine is under "vehicle down" priority. it has been 10 days now
...Been waiting all summer, just called Polaris about it and they said it’s now pushed back to December.
I am guessing this was last year?
7,931
6,692
I
I don’t know.
Maybe I got the last one ??‍♂️
You should still be riding though.
No gauge needed.
kylant
1,668
394
CA
asking this again, does anyone know? thanks
housing
gauge
install kit
gps antenna
v2v antenna
v2v harnes
Rob.G
81
37
Mobile
I'm with kylant... I have one coming this week to install on an electric-start sled. I got the unit and the install kit. What else do I need?
kylant
1,668
394
CA
after doing more research, it looks like the install kit comes with required hood harness 🤷🏻‍♂️
Rob.G
81
37
Mobile
I just got mine yesterday. The install kit does NOT include that $109 cable to connect to the battery... which is pretty lame if you ask me.
line8
1,558
532
West of East
Since it’s already an e start, I don’t think you will need anything else.
Mine did not have e start. It only worked when the sled started. I had to then buy the harness that goes to the battery, and a battery. I did the anti gravity and mount.
Rob.G
81
37
Mobile
Interesting. Good point too. Well, I ordered the harness.... maybe I should cancel the order and install it first and see.
Feb 15, 2023
77
65
Colorado
housing
gauge
install kit
gps antenna
v2v antenna
v2v harnes
I just bought 7s kits for both my sleds. All you "need" is the display itself and the install kit. Both of which the dealer can source. 1 of mine was on backordered but that backorder lasted all of 2 weeks. If you want the battery kit that's extra and allows you to run it while the engine is off (unless you already have an E start).
Sent from my SM-G998U using Tapatalk
