I
Got a high mileage 4200 miles sled that just started to die when idling. Usually it hasn't been an issue. Now what happens is that while warming up it may or may not die, but after warming up it dies when moving it and then have to hold down the throttle a bit while pull starting it then it goes no problem, full power.
It was running really crappy earlier today so pulled the plugs and the belt side was soaked. Changed that and both cylinders are good again and full power. Checked compression and only got 100 for each side, but they were exactly the same compression.
Last year I had a few times where starting the sled in the field I'd have to hold down the throttle to get it going as gauge would flash then die, but now it's way worse. Also sometimes the gauge will flash on and off when warming up though might be better now that I changed plugs.
Don't know enough about these machines and been reading lots. Is the motor done (though it shifts into reverse no problem and quickly)? It is a bit harder to pull over, taking off the belt and pulling plugs was no issue but with the compression tester in it was difficult again, harder than I remember for sure. It was really stiff the first couple pulls and wasn't that cold out. What about reed valves or power valves? Could they be an issue?
Anything else I'm missing that is a giveaway to what I need to do to fix this and be able to ride and idle?
Thanks!
Thanks!
