2011 RMK Pro Engine
K
Dec 16, 2023
1
Tahoe
Need a 2011 PRO Engine or one that will fit in. Looking for a complete engine. Mine exploded and sent parts out of the bottom of the case and reeds.
BeartoothBaron
1,243
1,320
Roberts, MT
I'd suggest posting a WTB in the classified section. It's kind of a long shot, but if you throw out an dollar figure, it might move someone. Another thought: you might be able to salvage enough parts, even with an exploded case, to piece together a good motor for cheaper than a used one. I'd be leery of slapping in an engine bought sight unseen, and they aren't easy to find. Unfortunately, a good, running Pro 800 engine isn't much cheaper bought by itself than it is with the rest of the sled.
C
Dec 14, 2020
493
682
93
I've found this to be the case with any sled that falls under the $4-5k range.
May as well buy a complete sled and part out everything.
Or go to Indy Dan and see if he has a complete one to sell.
I've seen a few sled junkyards on eBay. They generally have blown up engines which is why they are getting parted out. Sometimes there is one with a good motor and a broken bulkhead. I'd still do a 100% rebuild on one to make sure everything is perfect before you drop it in.
BeartoothBaron
1,243
1,320
Roberts, MT
I see that kind of thing too. You might get lucky and come across someone clearing out their garage. And with the Pro, just a running motor is probably $2000 if somebody's parting a sled, and I'd be thinking the same thing: I'd tear it apart, have the crank done if there's any question, and throw a top end kit in it. You might be looking at the same price as just buying one from Indy Dan.
Unless you've got a really trick setup, the rest of the sled is worth a grand or so (maybe a little more parted out). For a basic sled with a blown motor, I'd just part it out and move on unless I lucked out on another motor. My Pro is in real nice shape with a bunch of tweaks and upgrades, and I'm becoming more and more proactive: I check things over and spend a few hundred (a bit more this year with some crank work) to fix anything that doesn't check out. God willing, that'll keep it going until I'm ready to upgrade.
