R
My '01 700 has the xtra lite suspension (144) and I had a few questions about this particular setup. When I bought the sled the previous owner had the hd springs installed and I never got around to changing 'em out with lighter springs. Also the rear shock is a ryde fx... Is this stock? When I first took a good look at the rear skid I could tell things were not as they should be. On my last ride of the season the support strut that keeps the rear shock from over pivoting had snapped because it was rubbing on the shock itself and eventually wore enough to break when it hit hard enough. Also my middle outside bogey wheels managed to snap off of the perches sometime before I owned the machine and one of the rail end caps is mia... Could this all be related to one part being worn or out of adjustment? Maybe the hd springs are causing this (I can't see how) or more likely is this a bearing in one of the rear axle bogeys going bad and causing all of this.I've had that happen to me before and couldn't believe how much one bad bearing affected the rest of the skid. Any way sorry for the long thread but would appreciate some input. Thanks
