Rob has some great points.... your guys are priced too high...
If you are going to paint....
Hands down the best paint that I've used is POR-15... comes in black (matte and gloss), grey, siver, and clear
I was a doubter untill I got a freebie sample half-pint at a car show and used it... It sounded too good to be true.
No need for primer, just degrease and paint your sandblasted parts...
NO BS, this stuff rocks.
This stuff is as tough as 95% of the powdercoat out there and has held up on my Holz suspension for 2 seasons.. My A-arms are painted with this stuff and no chipping or peeling from heavy use in the bush (oops) and riding in west coast conditions...I have a freind with a Rock Crawler that runs the Rubicon all summer long that we painted the frame with this stuff... no peeling after 5 yrs of use and it is holiding up as well as the industrial powdercoated rear axle right next to it to the abuse...
The only downside is the lack of colors available.
Better than imron or Kronar 2 part urethanes that I've used...
It holds up to brake cleaner and brake fluid without damage...
This is a 1 part paint, moisture catalized and can be brushed or sprayed... I did a brush job on the a-arms and they look sprayed... this stuff flows out excellent for a smooth finish...
Wear gloves when using this paint... the only thing that will remove it from your skin is time.
This stuff is NOT highly toxic and is relatively low in VOC's.
If you dont use the entire can, make sure to put some saran wrap, doubled over on the can before you hammer down the top.. Once opened and exposed to moisture, it will harden in the can...
If you are going to spray it, make sure to buy the spraying solvent that they sell...
POR products also makes one of the best paint strippers I've ever used, short of full industrial "aircraft stripper".
Order a couple of extra spray bottles if you get this stuff... they hold up well to the stripper and you cant use hardware store varieties of spray bottles. Rinse the spray bottle with water to help it last longer... The gallon kit is the way to go.
On my truck bumper, it is still glossy after 8 years of non garaged use.
In Canada
http://www.por15canada.com/can/preventrustpaint.asp
In the USA
http://www.thefinishedlook.com/PartsDetail.cfm?Product=3
These guys also have a great price on fuel stabilizer for summer storage..
If you need colors, Quality Marine urethanes are better than any paints out there...
Check out "Briteside" urethane paints at
www.westmarine.com.
When you get into isocyanate based paints (urethane, catalized paints) you are dealing with some nasty chemicals that can put you into respiratory distress if you are not carefull...
