What can I clear?
Goin For Snow
1,110
230
South Haven MN
I purchased a 03 800 efi 1m today in near mint condition for 2700. Its a 144 want to go longer will a 151 fit in tunnel with a 2.4 lug? Or do I have to stay with the 151. With 2.0 lug
Idcatman3
MODERATOR: Premium Member
868
Idaho Falls, Idaho
We've put a 153x2.25 under a 144 tunnel. It worked pretty well. You'll want to be careful of the rear heat exchanger. We did different coolers so it wasn't an issue.
Idcatman3
868
Idaho Falls, Idaho
Stock drivers should work, as long as the pitch is right. We had to change to 8T 3" pitch drivers for the tracks we used. but the diameter of those is the same as 10T 2.52" pitch.
Goin For Snow
1,110
230
South Haven MN
with the 3.0 pitch tracks on the M series, arent the rails shorter in the front so track stabbing is more of an possibilty, than with the 1M a 3.0 pitch?
Should i look for extroverts and press on the shaft or is there a complete assembly i can buy complete with the driveshaft?
thanks
