Two place trailer tires
R
Dec 14, 2013
7
-1
1
I have a two place trailer with 18.5-8.5-8 tires on it and seems to pull harder than my tandem axle boat trailer. Is there a better tire size to go to that would help the trailer pull easier?
hansenmac
548
464
Deering ND
i dont know if it will pull any easier but i put 13 inch tires on they are taller and narrower. I had to make a 2 inch lift to fit them but the bearings turn much slower now and the tires shouldnt wear out as fast.
go high fast
1,544
466
83
Missoula MT
I have used the 20.5 x 8 -10 for years and have been totally satisfied. In general, more rubber on the road is better. Great handling, wear and mileage. Just love 'em. Carlisle I think but make sure you are getting the ones properly rated for load and speed as some of the china brands are a poor choice. Good spare, jack and a battery powered impact wrench and you're loaded for bear. I even travel with a can of the fix-a-flat.IMG00015-20110409-1829.jpgaaa sled trailer.jpg
P
Dec 15, 2018
1,060
872
Sorry for the detail BUT can a guy just buy the clam shell part of the trailer? I have one but iam sick of the road grime and covers are a pain lol
go high fast
1,544
466
83
Missoula MT
I honestly don’t know the answer to that question. But I think the answer is no. I’m not even sure if the Top Cap brand of trailers even remains available these days in that configuration.
hansenmac
548
464
Deering ND
you can buy a cover thats made of tarp and metal bows. i've read they pull tuff but i doubt its harder puller than a flat nose enclosed.
R
Jan 4, 2023
3
North Dakota
I own a tire shop. I converted my trailer from the 20.8/8X10's to a ST145R12. The ST145R12 are a little taller, so make sure you have clearance, or add a spacer between the trailer and the axle. These tires will last 3 to 4 times longer and only cost about 2/3 more. Radial trailer tires have better sidewalls for stability, make sure they have the ST designation on them. Don't by a passenger tire.
Coldfinger
538
Nebraska
I have been pulling a triton 10’ open, with no salt shield and 8” tires, since 1999.
Trips are 1,100 miles round trip, multiple times a year.
If you have a tilt bed trailer, installing taller tires will increase the angle of the deck when tilted, making it more difficult to load.
A few years ago I wanted the fiberglass cap but they were not making them any more.
I have pulled similar trailers with salt shields and they definitely catch more wind and are harder to pull. By this I mean your mpg will drop 1-2 mpg and your truck will downshift more in the wind and hills. This is with a 1/2 ton pickup.
Super 8
396
498
I did this 5 years ago and has worked great!
H
Sep 21, 2023
1
Houston
The effort required to pull a trailer can be affected by various factors, including tire size, load distribution, and trailer design. You might consider upgrading to larger or wider tires with a higher load rating, but it's essential to ensure they fit your trailer properly. Proper maintenance, tire pressure, and regular checks on wheel bearings and suspension also play a significant role in towing ease. Consult a trailer specialist for tailored advice to optimize your trailer's performance.
