J
joel97mustang
We bought a snobunje's tow kit and ended up breaking one of the metal pieces that tighten and loosen the strap. Needless to say we don't have one to use anymore. I have two ratchet straps in my backpack that I use instead. one end attaches onto the spindle of the other snowmobile, the other to the corners of the towing sleds bumper. And you can have the rider steer his or her sled that's being towed as well as slow it down.As stated above, pull the belt to allow the track to run freely. I do however like the idea mentioned about putting a tree branch in between the ski hoops to allow it to steer itself. Only reason I say this is because if you're in a tough spot and you need less weight to tow the sled out the sled can for the most part steer itself.
I haven't had any broken straps but the method of towing a dead sled is sound while the equipment may be faulty. That said I am going to upgrade to a stronger CAM buckle strap (which is what Snobunje uses)
Here's one rate to 1200 lbs breaking strength, 400 lb load limit
http://www.tiegrrr.com/TiegrrrStrap.html
Here's a video of snowbunje towing method. No rider needed on towed sled to steer or brake. It's awesome.
http://www.youtube.com/watch?v=MsocIEiLFgg
Always good ideas on this forum
