This is my first time owning a Cat with a set of Team Clutches and I want to get some information from you guys so I have a complete understanding of exactly how I dial these clutches in.
First off, I noticed that my set screw has been rubbing across the wear plate like many of you have also described. A decent amount of rubbing has occurred, yet I have not heard the terrible grinding noise you guys have described. I believe I saw a post where a guy had found a nylon tip that went over the end of this set screw. Is that the fix?
There is a set of of washers that lie in between the two sheaves. I am assuming this is for adjusting the offset correct? The deflection is adjusted with the bolt that screws in and set screw correct?
I am going to give these clutches a good cleaning while I have them out. I have always marked the sheaves so that they go back together as they came. But I read a few threads that claim that each sheave is balanced individually and it is not important which orientation the two sheaves go back together. Is this true? Reason I ask, would I be better to rotate the sheaves so the wear mark on the plate is on the opposite side?
I appreciate all the input fellas. I have always ran a cat and am 100% confident in the clutches from 05+, but these ones are slightly different.
