I dont have the graph and the dyno test done by Dynotech but we might have our answer there to compare the low-mid from SLP vs BMP vs Stock.
One thing for sure, the BMP gained a lot in the low-mid with the fuel controller.
I have the SLP pipe and can. I have MDS weights and added as much weight as available and still turning 8500 rpm at 9000 feet. Is it neck snapping power more no, but I am still adding weight and still turning too much RPM. The pipe/can has to be doing something.
Are you guys breaking in your sleds before putting the pipe on?
I could not feel the 9 hp gain on either of our new rmk axys sleds, but then again I did not ride them without the stage 2 kits. All I know is the axys is heads and tails above my 12 pros with head and can. My wife felt the power difference the second we left the truck and we only have 1.4 hours on them so far. I explained to her that once they are broke in they will be even snappier and have more power. Her reply was holy s!?t are you serious. I will say the throttle response and power is impressive, even in break in mode.
