Thanks for the answer.More air in the front skid shock and Gripper skis..
If u want easy steering, i recommend an RMK or Summit.
Cats have been hard to steer since 2008. Believe it or not, ur Alpha is easy to steer compared to the Mseries.
Sent it
HereHas anyone tried the lower mounting hole in the front of the skid? Maybe that can help??
Sent fra min LYA-L29 via Tapatalk
The Alpha already has all of the weight on the front 16" of the rail ... the rear is about 1" off the ground.Here
Okey I understand, thanks..The Alpha already has all of the weight on the front 16" of the rail ... the rear is about 1" off the ground.
Polaris has a different ratio in the steering, they turn almost 180° from lock to lock... vs cats ~140°.... not exact measurements but close comparison
Sent it
The Wyoming steering mod does let you turn it further. Basically it is a different bell crank. Do your research there are some tie rod clearance issues with this mod You can also buy the lay down post kit (steering from the trail sleds). Some guys have drilled out the lower hole in the front of the skid and used the bottom hole on the rear with success. When I say success I mean better clearance in deeper snow, it does make sense the steering would be easier also. Setting the air pressure in the rear skid and skis is just as important you need to get the right combination for your weight and riding style. Lots of threads on this. When you are done all this it still wont steer as easy as the Ski doo Gen 4 it also wont stand on it tail and give you surprises like the Gen 4 either.Okey I understand, thanks..
When I was driving the 2012 m800.
I remember Bret Rasmussen came with a kit to turn the ski's more on the side.
Is it possible to fiks the steering post so you can turn handlebars 180°
Regards
Rune
The front , center and rear shocks form a teeter-totter. Lowering the front and rear, and raising the center is the quickest way to lower ski pressure. Don't go above 60 psi in center shock per guidelines in manual as I believe it increases track wear (not proven). I have also heard remounting and lowering the skid works plus increasing the length of the limiter strap but I have no experience with that.Hi,
I wondering if anyone have an quick fix to get less ski pressure on my Alpha 165" 2019mod?
Thanks
watch your center of mass. I'm 200 w gear and I put my sled ( stock set up) on 4 scales and it came perfectly balanced- if you alter this COM point it will alter how it behaves in the air, usually not in a good way.
My got easier to steer, i think maybe u should adjust your shock pressure?Elevate steers just as hard
