if these sleds go down loading at the dealer or in the first mile, two things come to mind.
When you autopsy the motor:
if its a seizure in that sort of time you likely have severe detonation which can junk a piston in about 60 seconds even at an idle. Or are these motor stopping because of some other mechanical interference.
Over the years suzuki has had severe deto on the first 650's that grounded the whole fleet. Case bolts backing out and stopping the flywheel right out of the crate on the first zr700s.
Or when you unbotton that thing is there metal in the wrong place and stopping a bearing. Like loose metal shavings, loose nuts etc.
Cat /Suzuki usually want that destroyed motor back in a bag quick and unmolested. So the mysteries and information vacum continues, corporate cya is usually first priority.
