T
I am rebuilding a yamaha turbo vector and I am putting a rev tank on it. The tank I have is a SDI tank. Wondering if anyone knows if the Stock rev sdi fuel pump will work for the carbed vector. I already have a pump on the sled because it was turbo'ed before but I figure If i can use the in-tank pump it would be one less thing under the hood. It will make 60+ psi easily. I don't know the flow rate though. Figuring that it can flow enough for a 600/1000 SDI at 58 psi I would think that the flow rate would be enough for a vector at 20 psi max? Also see an advantage that the skidoo pump is made that it will suck the tank right to the bottom may be an advantage?
What are your guys thoughts? Thanks in Advance.
