Retrofit Silber Control System - Suggestions??
RMK900Tractor
216
50
Eau Claire, WI
I'm helping a friend out to retrofit the engine control system a 2013 Silber turbo kit on an 800 Pro.
Dobec / Silber came with kit. Tried Silber Bullydog system, Vipec but no luck keeping the sled from burning down.
Does anybody have a solid tune for a Vipec?? I like this controller but can get a decent base tune or any support.
Considering buying a MTNTK Bullydog system. Had a couple of guys say their tune is rock solid but want to get more opinions before dumping more cash into the sled.
Any other suggestions?
J
JJ_0909
ACCOUNT CLOSED
Nov 16, 2009
1,023
1,033
Why not add Silber's ECU reflash? Its not super cheap, but it should work...
RMK900Tractor
216
50
Eau Claire, WI
Thank you for the suggestion but I would rather quit snowmobiling than deal with him.
Sorry, I was unclear. My post should have stated any suggestions other than dealing with Silber. Look at the other posts - he can't make his current stuff run consistently even after 10+ years of producing kits.
J
JJ_0909
ACCOUNT CLOSED
Nov 16, 2009
1,023
1,033
There are 1,000 Axys kits on snow, many, myself included, run one without any problems.
Though there were certainly problems in the pre-ECU reflash era, (control boxes are tough) things are a bit different now.
Totally understand you are frustrated, but the lack of posts such as yours over the last few years should tell you what you need to know. ECU reflash works, and works really well. I know of 3 rental outfits even running silber stuff.
Though there are a few posts with problems in these forums, it seems every brand has something go wrong here or there. Again, there are *so* many sleds on snow now with great success you'd save yourself a lot of hair pulling going the Silber route IMO...
RMK900Tractor
216
50
Eau Claire, WI
Thank you for your suggestion.
AKFULLTHROTTLE
1,987
1,146
Alaska
No need to feed him.
Good luck on the tuning...
LongHorn XC
702
285
Illinois
Corey at Silber
Does anyone know if Corey still works with Silber? I've left about 5-6 voicemails and no response.
R
roni87
513
213
I Falls, MN
He is talking about the pro re flash. Not the axys. I had a lot of bog problems with my pro re flash kit until I put a boondocker box in addition to the ecu. Richened it up.
Seems like they did their homework on the axys kit. Not so much on the pro's.
I called mtntk about their tune before I put my old boondocker on and tried more fuel. That's The route id go. I believe 500 bucks for it.
J
JJ_0909
ACCOUNT CLOSED
Nov 16, 2009
1,023
1,033
A lot of the pro problems were clutching related in our experience. (belt slip) That, and I know they changed the map as time went on. I think his (the poster in this thread) kit has the dobek box but I could be wrong.
AKFULLTHROTTLE
1,987
1,146
Alaska
I had no tuning issue with the reflash on my 13 Pro.... Loved it!
Reeds, EGT sensor and clutching will all give you issues.
