I am trying to figure out what are the differences between
Gade X and the Gade BCK Country X
As far as i can figgure the Bck X has the Narrow contrl arms and the wider track
Is there anything else
Big John
thanks for the input
I am a off trail kinda guy but I also like to rail it a high speeds sometimes and thought that the R X was wider than the BC X ,
42.4 vs 38.4 to 40.1 respectively
BJ- the spec sheet shows summit ski stance, BUT the same sheet shows 48" over all width aka MXZ ski stance
so I thought mabey they had diff control arms and diff length shocks
I like the 16 wide track but not sure on the 1.75 lug on acount of MPG and Hyfax wear.
BJ- just add scratchers...MPG??
so Mabey I could switch the R X 15 wide to the 16 wide and go with a 1.5 Cross counrty style track
and not sure how much lower the gearing on the BC X is compared to the R X
BJ- 1.25 track is 25/45 so I would guess 23/45?? for the BC
are you sure that the BC X is as wide as the R X in the full wide stance and when and how do they measure them with the susp fully colapsed or fully
extended or at some predetermined ride height ?
BJ- ski stance is measured at rest...not collapsed
I want the wide stance with 16 wide so i figgure it would be cheaper to change the track and skis on the R X, rather than change the control arms,gearing,and track and posibbly the shocks on
the BC X
but if they share the same ski stance mabey its better to get BC X and leave the 1.75 on it (which track are they going with )
I am thinking the clutching and helixs will be different also any comment on this
