A
Hello folks,
I just purchased a 2016 Yz450fx that has a ninja back up kit. I do not want to run the nitrous as it eliminates too much storage space. When taking it off I found that a different rectifier had been installed, there are 2 extra wires coming out of this rectifier. One goes to a wire that has been removed from the ecu plug and the other goes to a dual connector located by the battery. The stock fuel pump wires have also been cut and power is now received from another wire that has been spliced into. There is an inline fuse on power pigtail to pump. Ground wire to the pump is installed on the subframe. Do you have any idea why all of these mods where done? Is this normal? Should I leave it as is or return all wiring back to stock? Any feedback would be much appreciated. Cheers
