bigpoppa05
Anyone have any pictures as to the proper routing on the Blow off valve and intercooler reference lines. I was told factory hooked up a bunch wrong.
What is this last pic suppsed to be?
So it looks like the hose from the intercooler to the brv solenoid has been disconnect. What would this cause and should I be concerned about damage or power loss?
You will not build any boost with this disconnected. It is common for this hose to come off. Try a better clamp.
Be careful with hose clamps. YOu need to find the right sized clamp.
If you use too big of one, as you tighten down the clamp the clamp get oblonged and will make for an air leak. I changed mine out and that is what happened.
I ended up getting rid of the gear clamps and using a pair of zip ties on each connection, being careful to getting small enough ones so as to make sure I did not end up oblonging the zip ties as well.
Holds tight and works great..............
