oil reservoir
E
edgex144
39
7
38
everywhere
Thank You.
Just wanted to say thanks to dan03rev for a great product. I just installed an insert into the tank on my 08 XP Summit and it fit awesome. The cap doesn't get stuck on after sitting overnight and it didnt leak any oil while I had the sled on it side. Great product and super fast shippin
DAN03REV
Oct 20, 2008
203
29
ALGONA, IOWA
thank you for the feedback .. :face-icon-small-ton
DAN03REV
Oct 20, 2008
203
29
ALGONA, IOWA
be sure to note your sled(s) and mailing address when you order ... i like to keep records for myself .. thank you ..
DAN03REV
Oct 20, 2008
203
29
ALGONA, IOWA
DAN03REV
Oct 20, 2008
203
29
ALGONA, IOWA
wanted to say thank you for all the feedback .. positive across the board .. made a slight change to make install a bit easier
that time of year again .. guys are picking a sleeve up for preventative maintenance .. thanks guys
PRAY FOR LOTS OF SNOW !!!!
JaxSledz
20
12
Snoqualmie, Wa
Buy the insert ... XP and XM
I put one on my XP and solved all the leakage problems,
Put one on my XM before it hit the snow the first time.
My XP was very warped, so I used the hot air blower on it until I got it back in shape .. no problems since !!!
Be careful not to over heat the tank opening if you are trying to reshape it (correct the shape)!!!
DAN03REV
Oct 20, 2008
203
29
ALGONA, IOWA
thanks man .. yah, i recommend a hairdryer to apply heat .. too much heat can cause damage .. apply a bit of oil on the sleeve for an easier install :face-icon-small-win
