B
My 08 Nyto is popping when going past mid throttle into high throttle. Air/fuel at idle is about 13.5 and climbs to about 14.7 at mid and then is pegged out at 18 or higher at high throttle. Boost will only go to 11psi and RPM only to 6500. I can get a little more RPM if I ease into throttle but then only 7100.
Any ideas? TPS and if so could someone walk me through the diagnostic screen.
I will be checking for vacuum leaks but this problem only started recently.
Could it be plugs? I am running a Boondocker box.
Thanks
Steve
Thanks
Steve
