What's the engine weigh and do you have to pull it out to install a head shim?
Thanks
Thanks
You do not have to pull the motor, you can rock it forward on the front motor mounts to install a head shim.........but I will tell you it is probably 30 minutes faster to pull the whole motor as you have better access to the cam chain tensioner and you will cuss a lot less. Just pull it out, install the shim and put it back in. One guy can lift the motor, I would have two to re install it.
