New Logan 31'
n2o
8
8
3
46
I had put $$ down on a 28' Trailswest but changed my mind after seeing the Logan. The Logan had everything I wanted to add to the Trailswest. 75k heater and invertor, 30lb leg tanks, 2 Fantastic fans, 50 gallon fuel cell and a flat floor, the whole trailer is covered in Berliner spray and has a galvanized frame and 7klb axles. This thing is a beast 9200lbs empty.
I did order a bunch of super track to run the full length down both sides and I'm a little worried about finding the supports to anchor in.
I would also like to thank Matt and Cindy at http://www.steerin.com best prices around.
powdrdaz
Jan 15, 2012
125
26
When I did mine I tried to guess but missed. So you can make one hole then crawl under the trailer and measure over from there.
I will warn you that as you get to the back they change the layout a little so measure all of them.
Great looking trailer you will love it
One last thing use a chalk line to keep them straight
Captainsheaff
65
82
18
Congrats on your new trailer guys!! If you haven't already installed your glides, I would hold off and see how you like it first. With over 1K load/unloads a season running 7-10 sleds a day, my floors have held up with zero tears or damage. Even top RMSHA racers running studs have had no problems... Just a thought as the glides make cleaning the floor difficult and can create uneven walking areas. Either way, you're stoked. See ya on the mtn
Justin
Scott
Super-moderator
68,917
11,082
W Mont
I love mine so far. Picked it up on October 5.
I've camped in it on two separate hunting trips.
Btw, when it's 20°, I can get about 3.5 nights on 30 pounds of propane. :)
revrider07
1,442
437
83
ND
Scott did you undercoat it and did you get side unload ? Im thinking with reverse i would not get that door.
AndrettiDog
6,270
2,438
Colorado
I only see 29' and larger trailers. That's too bad. Us guys in the mountains can't get those huge trailers in our parking areas. But nonetheless...incredible trailers!
revrider07
1,442
437
83
ND
I would think the side door would be nice if you keep more than a couple of sleds in there and you need the one in the front out.
I dont hardly ever use my front door on my 7 x29 now if i was ordering i would not order it personally has to be a 1000 dollar option. And its Another place to seal up.
GoBigParts
3,696
738
Michigan
www.gobigparts.com
On the gooseneck it doesn't make as much sense but like I said depends on your intended use. On my 7x27 we use the front door every time we go somewhere. We drive in the front and out the back. Always have 4 sleds in there. Helps clears the smoke out faster as well.
