My 850 is flood won’t start
I been on a ride this weekend with my sled, which is a rmk 850 2019, and I ride the first day without problem, but then the next morning my sled never start again. So I went to look on internet what would be the issue and I read that these 850 flood very easily (even if I never add this problem before for the 2 years I add it) and unplug the electronic to the pump, remove the spark and crank it a couple time, but even with that it won’t start and reflood immediately. I’m sure that I unplug the right connection so is there other issue that can lead to that?
my 21 would do the same thing fuel would actually run out the exhaust , but I could get it to start with new plugs. The dealer did a updated flash and someone suggested using a tss bypass. Not sure which one helped me, but I haven't had a problem since.
Unplug the flat connector at the front of the clutch guard.
Hold it wide open while pulling it over. When it starts and dies, plug it back in. Should start fine.
Was it always Constantly flooding? Like gas kept spilling out exhaust? Because mine is doing that atm and I don't know what's wrong. Checked cylinder walls pistons o rings gaskets everything is ok. But all my sled does is just keep flooding and I don't know what's the problem
Mine did it in cold weather at first start up, otherwise it ran great never left black spots in the snow. For a week straight it was below zero over night. Every time I went to start it it would almost fire on the first pull, but it wouldn't start. I changed the plugs and then it would start, but gas was running out the exhaust.
