This is my other 900 i have...love this sled..been nothing but awesome, trouble free and good to me..
still need to:
Install Carls CYCLE 975 Big Bore this summer...need to order pistons still.
repair/install Timbersled Fixed steering post
get custom light weight jackshaft made with wave brake rotor.
replace left fender, new shock vents, new nose pan vents
repair gauge housing
powder coat skid rails black
SLP white exhuast valve springs
Here is my list of parts on the sled..and where you can find them if you are interested..if they are not OEM parts!
Venting
•Longtracks Edge Side Panel Vent Kit (www.Longtracksedge.com)
•MoFlow Dash Vent Kit (www.Moflowvents.com)
•Mountain Fit Hoods, Hood Vent kit (BEST KITS AT THE BEST PRICE)
BODY
•Black IQR Hood (http://stores.homestead.com/williammoore/StoreFront.bok)
•SPG Seat Post (www.sledsolutions.com)
•Custom Black Seat Cover
•SPG 09 Front Bumper (www.sledsolutions.com)
•09 IQ Center Console
•09 IQ Front End Conversion (www.FTXMotorsports.com)
•09 Float Skid Plate
•Custom Black Smooth Lined Tunnel (SuperLiner-Bedliner)
•Black Powder Coated Engine Support Braces (done by myself)
•Black Powder Coated Recoil Housing (done by myself)
•Black Powder Coated Better Boards (www.snowmobilebetterboards.com)
•Black IQR Windscreen
•Black Skinz Rear Bumper
•Black Polaris handguards with Billet mounts
•Rider Select Delete Kit (Polzinhunter here on snowest)
•ProTaper Handle Bars (www.Ebay.com)
•09 Dragon 90 Degree Bar Hooks
•Fastlane Hood Strap Kit (www.Flaneinc.com)
•Custom UHMW Side Panel “RMK 900” (Polzinhunter on forum)
•’06 RMK 900 DRAGON “166 Track” Decals
•Pro-Armor Tether Cord
•Dzus Fastner Kit for Side Panels
•Fastrax Billet Throttle Block (www.FTXMotorsports.com)
•Snowy Mountain Lefty Throttle (http://snowymountainwintersports.tripod.com/index.htm)
•RSI Hi-Power Grip Heaters (www.RSIRacing.com)
•Billet Pull Handle (www.Ebay.com)
•BoonDockers Light Resistor (www.Boondockers.com)
•Gripper Skis
•SLP LED Tail Light Bar (www.startinglineproducts.com)
•Custom Made Gas Rack
•CFI LED Adapter (www.Bluhmenterprises.com)
•PowerMadd Extended Brake Lever (http://www.parkeryamaha.com/powermad...orpolaris.aspx)
•AMP Billet Gas Cap
•Timbersled Gauge Bracket (www.Timbersled.com)
•Polaris Underseat Bag
Engine
•Custom Billet Chaincase Cover (Polzinhunter on forum)
•Mountain Fit Hoods Intake Shelf (http://stores.homestead.com/williammoore/StoreFront.bok)
•’06 Rear Motor Mounts
•CompFusion Front Motor Mounts (CompFusion on forum)
•Custom Solid Billet Front Cross-Member
•SLP Push Arm (www.startinglineproducts.com)
•SLP Torque Arm (www.startinglineproducts.com)
•SLP Pipe (www.startinglineproducts.com)
•SLP Y-Pipe (www.startinglineproducts.com)
•SLP Billet Cylinder Head (www.startinglineproducts.com)
•CPI Racing Stinger Can (www.CPIRacing.com)
•FBF Throttle/Oiler Cable (FatBoyzFrenchy on forum)
•BoonDockers Nitrous (www.Boondockers.com)
•BoonDockers Control Box (www.Boondockers.com)
•HYVO 18/40 Gears
•Royal Purple ATF Chaincase Fluid
•Updated TPS Wiring Harness
•Armor Cord Heavy Duty Pull Rope (www.Armorcord.com)
•FNI Intake (www. Firenice.us)
•Black Powder Coated Belt Cover (done by myself)
Suspension
•Fox Floats Front Shocks (www.Foxracingshox.com)
•Fox Float Roost Guards (www.Foxracingshox.com)
•Walker Evans Rear Track Shock (www.Walkerevansracing.com)
•RYDE FX Front Track Shock
•225lb Front Track Spring
•MMP Freedom Axle (www.Mountainmachines.us)
•2 MMP 9” Billet Big Wheel Kit (www.Mountainmachines.us)
•4 MMP 5 ½” Idler Wheels (www.Mountainmachines.us)
•ZBROZ 40” Wide A-Arms (www.zbrozracing.com)
•09 HOLZ Billet Spindles (www.zbrozracing.com)
•ZBROZ 09 Sway Bar Bracket (www.zbrozracing.com)
•‘09 Sway Bar
•Custom Billet Tie-Rods (WIMPY on forum)
•HOLZ Billet Rail Brace (www.Holzracingproducts.com)
•07-up IQ Steering Boot Covers
•Ice Scratchers (SummitSeeker on forum)
•166” Series IV Track 2.4” Paddles with all windows punched/ported
Clutching
•Team TSS-98 Secondary
•66/42.46 Twin Trax Helix
•2 Derlin Washers in Secondary
•Black/White Secondary Spring
•3211115 Drive Belt
•Balanced P-85 Drive Clutch
•74g MTX Weights with 2g in outer hole
•Green/Pink or Blue/Pink Primary Spring
•Tri-City Performance Secondary Clutch Fan Kit (no longer available)
•Black Powder Coated Primary Cover (done by myself)
•Black Powder Coated Secondary Cover (done by myself)
MISC
•Warm-up Stand (www.Easymovecarts.com)
•EZ Sled Lift (www.Easymovecarts.com)
•SLP Clutch Press Tool for Primary/Secondary (www.startinglineproducts.com)
•SLP Clutch Holding Tool (www.startinglineproducts.com)
Wish List
•VE Boondocker Tunnel or custom wide runnig board kit
•SLP Cylinder Porting with Decompression Hole Plugging
•Custom Rear Motor Mounts, Torque Arm Assembly
•Timbersled sway bar block off plate
•Anti-Stab Kit
•Anti-Rachet Drivers
•Fully Clipped Track
•Heavy Duty Torsion Springs .377/47 degree
•Rebuilt Stator
•Updated 32mm Crankshaft
•Torque Master I Crank Modification
•ZBROZ EXIT shocks ALL the way around or Timber Sled Mtn Tamer Skid
•Black Powder Coated Skid
•KOSO Dual EGT Gauges
•Innovative AF Gauge
•FNI 09 Hi-Flow Stirrup Vents Black Powercoated modded on
still need to:
Venting
BODY
•Gripper Skis
•AMP Billet Gas Cap
Engine
•HYVO 18/40 Gears
Suspension
•‘09 Sway Bar
Clutching
•3211115 Drive Belt
MISC
Wish List
•Anti-Stab Kit
•Rebuilt Stator
