M
02 700 is leaking antifreeze only when it is running, it is dripping off the bottom of the water pump housing. I have replaced the seal that is pressed into the block, the seal that is pressed into the back side of the water pump impellar, and the seal on the bolt that holds the impellar on.
Did not appear to have a weap hole in the water pump housing (like a car pump has)
I even used some Permatex along with the O-ring on the water pump cover....
Any ideas?? Is there anything behind the water pump housing that could be causing this? I can't see underneath and have never had a motor out....
