MC transformation begins!
Chewy22
1,996
1,371
Montana
Chewy did you use a punch?
I used metal hole saw blades. Didn't have a 2 3/16", not even sure they make them, used a 2" then filed out the rest. It was a little rough. I used the template as a guide (no drill bit in the hole saw). At the start, I ran the drill in reverse to make some guidelines and it doesn't bite much. Used a smaller cordless drill so it didn't bite as hard when switching to forward.
I wasn't sure how else to do it and I had the hole saw blades so ran with it.
Chewy22
1,996
1,371
Montana
Might be a little tough with the existing holes. Would have to hold the drill pretty steady when one blade was in the open space.
Cool looking tool though. Would be great for those off size holes.
4,080
2,802
would this work?
I've never seen one of those before. Interesting for sure
Working from the inside of the tunnel I think I'd measure across the new hole both ways and mark center. Then take a hammer and center punch and hit the center mark good. That will hold the pilot bit on the closest size hole saw. If the center mark isn't on metal then the wood block on the outside of the tunnel would work to hold the pilot bit as olymon suggested. A jig saw with a metal blade for rough cutting would work too. Clean everything up to final dimensions with an air or electric dremel tool.
KMOD
463
Firth
kmodsnowmobileparts.com
Yes,
Once the inside template is in then just saw at opposite angles with a jig saw or reciprocating saw to get 80% of the hole cut out then finish with a die grinder with round carbide bit, it will go quite fast and the stainless template will keep the bit from over doing it. Many ways to do it, mine went pretty quick this way.
As you can see after cutting out the outside of the tunnel I flattened it out with a dolly and then installed back in the hole to keep the brake unit flush with the tunnel. I riveted it in then cut out the large holes.
Kevin
Chewy22
1,996
1,371
Montana
How concerned should one be of having the bearings there like that without any oil?
Top bearing will be replaced with a sealed bearing that comes in the TKI kits. The bottom bearing will be covered with a seal that comes with the TKI kit. As they sit in the photo, both are loaded with grease.
Chewy22
1,996
1,371
Montana
On my 16 (MC setup) with no shocks mounted, the front of the skid pretty compressed and the rear hanging completely free the very tip of the rails hits the drivers; not a lot. See photo. When you put the slightest pressure on the rear it clears all day long. I'm not sure how far the skid can compress with the shocks on or if it's even possible to compress the front (with shocks) and the rear hang all the way down? I'll probably grind off some of the plastic on the rail tip. With the new approach angle I don't think the track will ever hit the area ground off.
Chewy22
1,996
1,371
Montana
Can someone with a MC do me a huge favor and take a close-up picture of your rail tip. It looks like the plastic on the MC's are not as thick as the plastic on the 16s. If that is the case I may just order MC rail tips. Thank you so much!!!!!
Chewy22
1,996
1,371
Montana
Does it looks a little more squared off at the tip compared to the 16?
CO 2.0
2,994
Fort Collins, CO
Dont even have plastic rail tips on my ice age rails and 3" pc on my axys. Ice age just has you run anti stabs and thats it. Are your drivers hitting the 16 rail tips when fully collapsed?
Chewy22
1,996
1,371
Montana
No just when the front is pushed up. When you start compressing the rear it pulls the tips way from the drivers.
KMMAC
1,461
207
Mount Vernon, WA
My concern would be, that one little downed tree that is just under the snow and you happened to be gassing on it. Could the 16 rail tips be trimmed and put the 17 caps on?
Y
yamahajohnson220
222
128
I agree. On my yammi's I've had to cut some of the rail tip off and re-rivet the cap back on to clear drivers. It's amazing how much the skid moves forward when you think its moving back in motion.
