Marine Grade Plywood Colorado Source?
Coldfinger
538
Nebraska
Not sure but you might try some lumberyards. I am sure they can order it or point you in the right direction.
On my Triton 2 place open, the outside left and right edges appear to slide into a channel so if installing thicker material you will need to router the edges so they are thinner.
J
Oct 15, 2013
221
95
Breckenridge, CO
I’m Fairly certain you can get it at or thru the Dillon marina. But really at the end of the day treated is much cheaper and would have to be on yoru sled deck for so long before it hurt anything the useable life of the deck itself would be past.
Coldfinger
538
Nebraska
How long would it take for treated lumber to corrode the aluminum if in direct contact?
Any type of coating or protective layer which could be placed between the plywood and aluminum? Maybe thin joist tape on those spots.
