I think I have a problem..What you all think???
06 RMK 900
1,621
343
35
Mandan, North Dakota
OK I think I might need to do a little work on my Rear Suspension. I took a few pics
This first one is me holding up the back end all the way up.
If I let go it then falls to this
If I get on it, it goes down even more to this, and doesn't come back up at all.
I have tried adjusting the Torsion springs and the little adjuster at the ende of shock. It seems like it used to come back up more by itself and I had more cushion. So what you all think? I'm guessing I need a new back shock?
jafraune
705
72
wyoming
if its on the caster wheels it will always sink...i think its a pressure point or something...
i would let it sit for awhile mine seems to do the same thing after i let it sit on the casters for awhile then it gets back to normal....maybe Im just mental or something though lol
06 RMK 900
1,621
343
35
Ok I will have to give that a try, Just seems odd that I can push it all the way down just about to bottome out and it comes up only a little bit.
The Bob
504
84
MN
Get the shocks rebuilt. They are blown, maybe just 1 but probably both if you rode it alot with 1 blown out. I am not quite sure what is one that sled for shocks (rebuild wise), just send them out or have them rebuilt by someone that knows what they are doing.
06 RMK 900
1,621
343
35
Wish i could they can't be rebuilt
Rob1334
ACCOUNT CLOSED
Feb 26, 2008
4,965
770
Bismarck, ND
Had same problem last year Casey, I was stressing going WTF then waited till it got a little colder and let it sit on its own, shocks perked right up and was fine by the time I rode.
F
f15ejedi
289
52
Anchorage Alaska
I had a coil spring that was broken on a different model sled and didn't see it until I took it apart. Double check them also but your shocks are blown.
06 RMK 900
1,621
343
35
What kind of shocks you all think I should put in there. I want something good but not kill the check book. I can't stick much more into my sled this year.
Links are great!!!
F
Fast Freddie
147
57
Shoshone Idaho
05 stock shocks
I've got a set of stock shocks for the rear i took off my 05 900 they should work. Took off at about 300-350 miles. If your looking at saving some $$ pm me if you want them sell cheap to help you out.:cool:
94fordguy
5,244
Yakima, Wa.
Yup, the caster will exagerate any sag you would normally be seeing... Especially putting it that far back, you are moving the pivot point all the way back instead of splitting the weight between both skid springs evenly. Also, you can crank up the preload on your spring cams and that will help with the sag issue as well.
diamonddave
Chilly’s Mentor
5,577
3,890
Wokeville, WA.
As a Canadian would so eloquently put this, "Dude, your rear torsion springs have sacked out." I've replaced about 6 or 7 sets of rear torsion springs on these 05 and 06 IQ's. In fact, Polaris even makes heavier rear springs for us heavier guys which I'd rec if you weigh over 190 lbs as the stock ones even for light guys have been found to sack out premature.
Normal...
Nov 27, 2007
409
48
my 900 rear springs sacked out in about 700miles i would advise heavy duty springs may be a bit stiff at first.Also the stock shocks dont take much abuse i would try to find some used rebuilt shocks.
BIGGDAWG
1,860
676
Waverly, Iowa
I agree with these guys the rear springs are sagged out. a three in our group did the same thing. we upgraded to the heavy duty springs on 2 of them and they work great. I put the timbersled skid in mine and love it.
the new springs are a little stiff for the first ride but they break in and are 100% better than the stock ones.
