A fresh motor, new pistons, rings, cylinders etc.., need time to finish the machining process.
New ball bearings also need some break in time.
Even though the engine was machined to perfection, all components need to 'get used to each other'
All engines I build when first run get pretty much the same break in time. I will initially fire them up and keep the idle a few hundered rpms above normal until the cylinder is warm to the touch. Cool down time is next. I will let them totally cool without any fans blowing on them to accelerate the cool down time. Once the engine is cool to the touch. I will fire it up until warm to the touch again, then cool down. Repeating this proceedure 5 or 6 times will let the pistons and rings, bearings machine themselves needed for smooth operetion, minimal issues, and bettter overall performance of the engine after long term use.
Do add extra oil, on a 2 stroke, to the first tank of fuel and when the engine is initially started, hold the oil pump wide open to release trapped air from the oil lines and give the tight engine some extra lube. Note the air in the oil lines when the engine begins to smoke heavy. No air present, release the oil pump to normal operating position.
Revving the engine cold or running it like you stole it, from the first initial start-up can be asking for trouble from scored piston skirts, chattered rings harming ring lands and cylinders may result. I have also seen crank bearings chatter which will lower engine performance and cause drivability issues at higher rpms.
I prefer mineral oil for initial break in, but following the above outlined initial start-up proceedure, synthetic oil use should be fine
Enjoy the fresh engine overhaul
----- Gimpster -----
