HAS ANYONE EXPERIENCED A 2019 AXYS 850 ENGINE FAILURE ?
turboless terry
5,566
6,767
Big Timber, MT
A friend towed one out from Big Sky this weekend with a locked up motor. Had 50 miles on it. Saw the video of 3 sleds linked together (2 pulling) to get it up the hill from where they were. I don't know any more details other than that.
I told Mueller that it looked like that poo keeps up just fine with his 850. He said it does on the end of a rope. I think that was Coulter Todd's 850 poo. He isn't very lucky because I think his last years axys blew up also.
cascadesnowjunky
1,338
660
Kennewick WA
It is an engine with two individual jugs and two piston rings, it is not a polaris unless it is an old big block, but don't look like it.
Feb 1, 2013
At 90 miles i noticed my belt slipping like it was wet, took panel off and noticed a little oil build up. Rode another 10 miles to get back to trailer with it slipping another 5 times. At trailer i pulled the panel of again and noticed lots of oil. Just got it back from dealer... Oil line to PTO bearing had come off because it didn't have clip/clamp to hold it on. Engine and bearing are fine. I would recommend checking line.
LPIdaho
271
IF,ID
If they go down it will be in the first two hours. If you are past that then your engine is good to go.
Teth-Air
4,561
2,790
Calgary AB/Nelson BC
www.specified.ca
So with a cell phone you can get a pic of the hose behind the clutch. This is one hose you should check anytime you blow a belt. I could easily see it get pulled off.
Dec 16, 2018
27
13
My 850 went down today. 78 miles on it. Took off from a stop mild throttle and sled shut right down (almost flew over the bars).
Pulling it over motor feels tight and it does start but sounds like crank bearings. Not good
revrider07
2,034
1,001
ND
Just making an observation here seems like alot the 850s that are blowed up are posters with low post numbers. Hmmmmmm
turboless terry
5,566
6,767
Big Timber, MT
So if they have a 1000 posts on snowest that means their 850 won't blow up or the post is legit. Give me a break. I have a buddy that blew his up at 50 miles. Who cares. It means nothing. Just means he got unlucky for the moment.
