14RMK144
So I've never tuned my sleds, always rode older, just to be able to ride. (all I could afford, no extra money for mods lucky to keep em running). Till last few years.
So my 600 RMK has 20/42 gearing. If I go to 19/43, will that give me a little ski lift when I pin it? And a better hole shot? Or will it be a trencher off trail?
I see these 800's wheelie like no tomorrow these must be turbos? Or at least big bore kits? Don't quite have that money this year, hope to do big bore next summer.
O.M. says also 72 pitch, whats that? Thinking its the angle of the gear teeth, need a chain to match?
If I change gears will I need a new chain or when you buy new gears? Or do they have options of pitch so you can use same chain. Sled only has 1200 miles so chain is still good.
Thinking this would be the least expensive, and easiest for me to do myself.
Whats my other options? Clutching? What changes would I do to the clutches. Is it do it yourself job. Or need shop to do it. I've changed weights but that's the extent of any clutch work I've done. Handy and mechanically inclined, but not a mechanic. I've done top ends, cleaned carbs and changed jets, track swaps, changed out suspension then set camber and alignment, all maintenance and stuff like that.
Any advice or pointed to resources is highly appreciated. Thanks in advance.
