Anyone using Evans waterless coolant in their snowbike? Outcome? Issues? It sounds like a cure to inconsistent rad caps and boil overs.
how are you figuring that??
Why do I need it? Same reasons wwillfo mentioned. I've tested four rad caps in the last couple years that started the season holding enough pressure that the bike wouldn't piss coolant till 225 or more. By the end of the season they would be down 10-15 degrees resulting in losing coolant on long pulls or anytime the bike idled for few minutes. Sometimes don't notice till the bike doesn't cool down when it should because coolant is low. I want to run my bike near 200 degrees and don't want to worry about pissing coolant when I hit 220. I do understand that given the slightly reduced heat transfer ability the bike might run a bit warmer and that's ok.
