O
Just bought a non-running 03 Polaris 700 RMK which had an exploded piston and scored jug. While waiting for a top end kit and new jug to arrive in the mail, I split the crank case to look for pieces of the skirt (located 10).
While I have the case open, is there anything I should replace/inspect/service? Should i try to pack the bearings with Isolflex?
So far I've given the crank assembly a pretty good solvent wash and re-coated the bearings with 2cycle oil. A couple of the bearings had a slight grumble prior to the solvent wash, but the noise went away after I oiled (piston particles infused oil in bearings I assume). I have new seals on the way, but can't really afford to replace bearings unless absolutely necessary.
Sled has 1200 miles. Guessing a leaned out or plugged carb caused the problem. I will be addressing that next.
Any advice/thoughts would be very well received.
